My baleno 2004 jxr now a days giving problem in starting at petrol. some times just 1/2 self, some times 2-3 long selfs followed by a lethargic start. and some times it takes 8-10 selfs and starts like coughing style and then rapid pressing of accelerators gives result. after start there is no problem in petrol running, no missing, under power, or any other abnormality.
Gas is fine all the time. if i direct start the car on gas its ok.
some mechanics say fuel pump is bad,... but i have check the pressure its good...fuel pressure is around 35-38 psi in engine bay.
some say pump is intermittent....
some say electrical problem...
i got the injectors cleaned....,fuel filter changed, spark plug and current tested. CNG and Petrol mixing tested.
scan through computer no error found
