Use your phone in safe mode and then see if battery drains quickly or not and report back the results.
Safe mode disables user installed apps, which are usually the culprit for quick battery drain.
Battery drain can be due to system apps or user installed apps. Use of safe mode will determine that. Once we find out, then we can guide you better.
Also check these two things.
1- Make sure that all your apps are updated.
2- Also check firmware updates.
Settings > about device > software update.
