A bipolar capacitor with at least 100v rating is needed.
The thing is even when running active we can't do anything about turn on or turn off pops from amps which are full range signals and therefore can damage the tweeters.To avoid phase shifts, we plant our capacitor on a point that is so far away from our active point and still provides protection that the output has attenuated so much it doesn't make a difference.
Here are two extremes, the focal is a 4ohm driver and let's say we'll cross it at 4k.We'll use the passive crossover point at least one octave below the active point to avoid any phase issues.If the passive point is near the active then we'll definitely have phase issues as the output from the active slope hasn't attenuated the driver enough hence there is interaction.
8uf cap will be problematic since we intend to cross at 4k
This would provide enough protection without introducing a phase shift.
As with many things there are multiple school of thoughts,you can choose the one that suits you in this case protection vs no protection.This is subjective and my personal opinion has been stated above.
Best of luck...
Sent from my GT-N7000 using Tapatalk
