I need your comments about turning the air intake pipe and jointing it just behind the front grill. so that on high speeds cold air will be pushed inside throgu this pipe causing more HPs..
is it possible? any comments
yes, get a rubber pipe, attach it to the place where the old pipe ends(where the cone is connected right now) and connect the cone to the other end. but tie the pipe to something, you dont want it to go into the radiator fan
but a flexible rubber pipe will bend and block when car is moving slow or is stopped..it will block the air passage..
