Please Help about function of this button of Mehran
It looks like the recirculate button. In ON position the air from outside will be blocked. Off position the fresh air from outside will come inside the cabin. Experts/ Mehran owners can confirm. I believe if you pull its ON and push its Off in Meharn.
its fully computerized fresh Air button of Mehran's sophisticated Climate Control system. Bro use this fresh air button with care.
When it operate, i mean,if i pull it what does it function and if if remain off position what it function
pull means no fresh air and push means fresh air in enabled....
Sent from my TCL A909 using Tapatalk 2
pilot seat eject button in case of emergency
pull it when using a/c, it may increase cooling, but i dont think it makes much of a difference in mehran's body.
Nos...
When you know you need to brake hard and you won't make it, *Mayday, Mayday- whoosh eject seat *
Naah, just joking, it's for recirculation, meaning that the cabin air is recycled. Use that with ac turned on.
Sent from my HTC One_M8 using Tapatalk
LoL for real heregood one!
Hahahahaaaaaaaaaaaaa thanks
this button is a nightmare....i have tried to operate it in many mehrans...but i broke it everytime......its kinda stuck all the time.....u try to push it hard...it wont botch......u try to pull it out and u will end up staring a plastic piece in ur hand....
whenever i see any mehran.....unconsciously i notice this function....n an uncontrollable itch to operate this function
@all
One of the most sophisticated buttonsI keep it pulled upwards to recirculate the A/C Air but it is so automatic that after driving for 1 Km it goes half way downward by its self
It is a switch to either allow the fresh air from the outside to the cabin or recirculate the inside air of the cabin again and again.
The fresh air should be used when you've a heater switched on.
Air should be recirculated while using the A/C because of pollution in Pakistan however you can also use fresh air for A/C in hily areas where the environment is pollution free.
Sent from my LG-D802 using PW Forums mobile app
I just took this button out of my Mehran and kept it in the glove box
LOL ... cool answers !
I had the 'fresh' air circulation completely blocked, as this switch rests somewhere in garage...
don't need much of the 'fresh white' (dense) air to fill the cabin.
lol
a very late question the cable which pulls the duct is slipped and now i dnt know where is the lever to stick it back again.can someone guide me here as when ever i cross some dirty place all the smell came into the car.plz i need help if some kind soul take some pics and post it here
Hi faisal, same problem i am facing, do you know where to stick it back, anyone please help.
This topic was automatically closed 10 days after the last reply. New replies are no longer allowed.
