5afe engine head gasket is weak .I want to swap 2nzfe engine.please suggest
Replace head gasket. 5AFE is a good engine.
Parts are not available in the market for 5afe engine.as balloons are coming in the radiator
Head Gasket will be available with big toyota parts dealers. Btw swapping 2nz/1nz in AE100 chasis isn’t easy. Main difference is it has exhaust manifold at back of engine which leaves very little space with firewall or may touch steering rack. If you will go for NZ series then go for 1NZ it is tad bit better then its younger sibling 2NZ.
Here in Multan .parts of 5afe engine are not available .and are too much expensive because kabli parts are not avaliable.i am changing engine due to parts availability.
I would advise you to change the car infact, swaps are not reliable most of the times. Better buy corolla 2003-2007 if you have the budget it has 2NZFE in xli and gli variants. Parts are also available easily everywhere for this model.
Thanks
Exactly change your car
I change my car gear box from Auto to manual .is there any need to cahnge ecu of engine
yes your ecu needs to know about shifting so it can retard timing for smoother shifting
A /t or m/t ecu..please share pic of manual ecu .
Just visit Lahore Bilal Gunj, get head gasket and get it installed. Don't swap
Is there any issue in installing head gaskit
Head gaskit effect car ac system?
not if done properly
I am afraid of change head gasket because parts are not available .another problem can be arise while changing head gas kit.
Please guide me for mechanic. Multan
Sir parts are easily available in Multan. Didn't find any difficulty in getting parts for my 7afe (which is rare than 5a).Go to Malik Autos near FBR house, otherwise Lahore autos in Auto plaza also has all the parts of A series engine.
Ap apna eletriction ka btia.jis ko Mae apne gari check karwo.
Go to Ustaad Mohaiyyuddin. His workshop is in the street opposite to Sessions House, Multan.He is a sensible guy with latest scanning equipment.For exact address, I will provide you his cell number.
