If the low side line in the engine room is chilled - then you need to check the heater system in the dashboard, it maybe stuck open.
If the low side line is not chilled, then you need to check the system pressures, if there is not much difference between the low and high side then most probably the the expansion valve went bad. It can also eject gas from the system if it completely blocks.
