@ yasirsa
Boschmann is a canadian company :*
oh come on mate didnt you get i was kidding ? ur an old player here and i know what you have in your ride...i even commented in your threads...
i just wanted you to try and grab some GUTS pics from ROE... thats it.... otherwise hells yeah i know what you running...impressive to say the least..
@mohsin lol i know mate you are kidding i am just taking good interest in your thread its a nice thread though cheers
this thread deserves more contribution man
this is what im runningcaliber monoblock ( a little less than 1000rms ) crunch 2 channel 500w (150rms) premier 4 channel amp ( bought it as a temporary solution ,till i got my monoblock) having some trouble uploadin the pix at the moment
Peoples make this thread of only Posting AMPLIFIER PICS + Concentrated discussion Over it
Just Bring it on whatever you have from Lowend to Highend
Solid Audio F47 (the pics aint uploading so copying from ampguts)
Solid Audio F41 and Solid Audio F15d
Solid Audio F-47
4 x 100W @ 4 ohms (14.4V)4 x 160W @ 2 ohms (14.4V)2 x 260W @ 4 ohms bridged (14.4V)Fuse: 2 x 40A
Solid Audio F-15D
1 x 800W @ 4 ohms1 x 1150W @ 2 ohms1 x 1500W @ 1 ohms
Fuse: 4 x 35A
here iz my amp PP-AM15001
Powerplant Monoblock AmplifierSuperior Thermal ConductivityPowerPlant amplifiers feature superior thermal conductivity ensuring heat dissipates efficientlyRugged Amplifier CaseSingle piece extrusion with seamlessly matched die-cast end caps which protects connectors and internal components Over-sized Mounting FeetThe oversized mounting feet with their recessed holes provide secure and discreet fastening points.Over-Sized Power ConnectionEnlarged contact surfaces for high current connectivityStage 2 System Management PanelMulti-function management panel enables you to refine the characteristics of the signal to suit your audio preferences.Multiple Fuse ProtectionMultiple fuses protect internal components and are easily accessible for quick changes in a competitive environmentProduct Specifications
550 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N850 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
Max Power Rating: 1500 WattsMax Current: 100AFull Rated Power Distortion (Max) 1kHz: 0.15%THD @ Rated Power 1kHz/100Hz: 0.1%Frequency Response Hz (-3dB): 10Hz - 250HzSignal to Noise: >90Variable Low Pass Filter: 12 dB/OctaveBass Boost @ 45Hz: 12dBInput Sensitivity: 0.2 - 8VInput Impedance: 47KFuse Rating: 25A x 4
Solid Audio F-11D
600wrms @ 4 ohms 850Wrms @ 2 ohms 1100Wrms @ 1 ohms Fuses 25a X 4
