SinglePlayer is a powerful audio player for consoles running WINCE 6.0. Made under the alternative shell SingleMenu and NewMenu.
Using an audio player will make the sound more interesting (there is an equalizer). The player also has internet radio (an access point can be made using a smartphone). Also, you can listen to the radio station on your smartphone, and send it via MMS via MMS.
All player features:
Show / Hide text
- High performance and speed of work
- Finger-oriented
- Powerful design engine, allows you to make any skins
- 13 band equalizer. Fine-tune the equalizer settings.
- Effects: reverb, echo, horrus, flanger, tempo, pitch, compressor, distortion, phaser, freeverb, autowah. Tweaking effects.
- Filters: high, low, bandpass, peakingEQ, notch. Tweaking filters.
- Antibanner proofreader
- Full playlist (add, move, sort, erase from disc, play, navigate, clear)
- Search for tracks, allows you to search for tracks in the current or all playlists, in titles and tags.
- Built-in keyboard, support for up to 10 layouts.
- Playback queue, allows you to create a list of tracks that will play regardless of the playlist.
- Support for multiple playlists, up to 20
- Support for id3v1, id3v2, vorbis (flac) tags
- Rewind tracks
- Favorite tracks in the playlist
- Favorite tracks to a separate folder
- Toggle playback of tracks by album
- Multiple selection of directories and tracks to add to the playlist
- Save positions and track numbers for each playlist and automatic playback when you switch to the desired playlist
- Swipe through the explorer and playlist
- Search for USB disks and fast playback of their contents
- Playing formats mp3, flac, wav, ogg, aiff, m4a (aac, alac), mpc
- Displays the album cover and the logo of the Internet radio in the screen saver / player
- Add a single track, directory, subdirectories to the playlist.
- Sort the playlist by quick sorting.
- Save the position of the track on exit.
- Play the tracks in a scatter, in a row, one track.
- Playing playlists in scatter or in turn.
- Delete the track directly from the disc
- Internet radio
- Smooth sound attenuation when you stop playback and increase at the start of playback
- Quick and easy navigation through the file system, displaying files and folders in a grid or list
- Playing tracks according to the set genre in the equalizer. The genre is read from the tags and if it matches the current style of the equalizer, it is played.
- Auto-tuning of the equalizer for the genre of the track
- Rendering of the visualization, in the form of a Spectrum, into the splash screen and the main player window
- Support for skins (set via the menu)
- Display of the processor load
- Broadcast and reception of control messages
Download from follwing links
https://drive.google.com/file/d/1Cn61q6DGHak90Nqm8-tmGTe2FCKOH-KX/view
Extract Using WinRar on PC / Mobile
Paste in SD card
Plug in the card in LCD
use my this page for opening custom exe file on CAR
