@Xulfiqar Sir i want to know what precautions should we take when we overhaul a 2.5 kva generator?
I have to replace to block as it has been cracked... and also the connecting rod is broken, now i want to overhaul then engine, the mechanic said that he will install new block and he will also bore it...
Now i want to know how to make sure that rings seat properly, as i have read your post regarding break in period of car that we should not hold on one rpm and also not idle for break in period... So how can we manage that on generator?
And also tell me other things like should i run it without load initially and also tell me can i do the break in period on gas or not? and plz also point other points of precautions...
@Hassan1991
@brownrose78
@capsat
@ etc
**Yes i do have copied the title
