Hello!
Well As I Am In Search And Need Of These Battery Jump Cables.......So I Went To Store To Get Them ......!! Got 2 Qualities....! One Is For 600rs....Which Is So Thin To Hardly Live Up Long...Will Get Heat Soon As Wire Is So Thin......!!
2nd 1200RS......Quality Standard Is Ok....Much Better Than Those Ones...But Not That So I Need...In Short...1200Rs Won't Worth.....!
So I Decided Now To Have Them Built Them Up Myself With Some Thick Cables......!!
So I Went Off To JunkYard Market To Get Wire And Got HITACHI Heavy Duty Wire....! Can Pass High Voltage As Its Rated Till 1100V....! So Works Pretty Well For Battery Jump Cable.....!
Required Stuff..!
High Tension Wires As For Your Need..15ft Is Enough...!
7.5ft For One Wire As I Buy
Crocodile Clips...!
Just Some Tools To Get It All Together With Some Skills...!
Costed Me 770rs....650Rs Wire 15ft +120rs Clips
Over All......I Think Its Better Than That 1200rs Wire I Will Get.....The Wire I Got Is Much More Heavier Than That....!!
Well I Have Got Some Different Type Clips As The Main Thing In Them Is They Are Fully Plastic...Just Have Center Piece Inside Of Copper....! Good Thing About This Is That If In Case Two Clips Meet Being Attached On Battery..No Short Circuit Occur As Mostly Did With Full Steel Ones...!
Here Are Some Pictures Of The Job.....!!
The Crocodile Clip....!
Copper Teeth...!
Cleaning Them With Sand Paper....
The Cable I Bought......Its So Thick :p...Looks Like Some Rubber Gas Pipe..!
Before Cleaning....!
After Cleaning......!! Shinyy...
Now Stripping Wire To Get Into Clips....!
Its Desi Jugar...Using Different Tools To Open Up The Clip To Have Wire Punched Inside...Damn...Once Clip Close On My Finger With Force...I Can Still Fell Pain
Its Done...!! After So Much Hassles...Damn Punching In Clips Like These Is One Hell Of Job....!!
Final Product....Tadaaa....
Will Post Some More Of My Stuff I Have Got... Later!!
Regards
Farukh A.K.A SER_GTR
