I agree with you brother, these engines have proved to be rock solid. In my case I am maintaining this engine since 2009 as I own second hand. During recent gasket work I have noticed 0.50 piston so this engine is overhauled once in his life. Pistons were still in very good nick.
The only issue I am facing with this engine is the heating issue and I am still unable to defeat it completely. I am not allowed to run AC, merely after 10 kms running I have to switch off the AC.
Khair with AC scenario there is lot more to discuss, briefly I am using the light possible compressor these days and that is of which comes with Duet / Passo one.
Recently that is yesterday I had a trip from KHI to HYD and then back to KHI. I had no issues whatsoever. I used old radiator cap which is not air tight, small rubber packing (from valve) removed. In running of around 500 kms (without AC), there was no water level drop, no heating issues at all.
