[quote="luckycar, post:8, topic:464153, full:true"]
just a good mechanic to swap. from scrapyard
Any requirement in documentation?
yes engine number is written on block. you need to get that number changed on your car's papers by showing purchase invoice from scrapper or whoever you bought it from
Alright
My car is stuck now. Gasket blown and moisture found in spark plugs. Mechanic says need to open engine block to see how much water damage cylinders. What do u say?
[/quote]
If your gasket is blown head needs some work but i heard that its a temporary fix a permanent fix would be change of engine get an efi engine called g10b or if you go for economy and a bit lowered price get a g15a as g10b is more costly.
