can any one tell the price for A442 Transmission currently i am running 1FZ-FE engine.fell free to suggest what other auto transmission i can use with 1FZ-fe
was quoted 60k without Torque Converter in Bilal Ganj Lahore, claimed to be Dubai imported vehicles. Torque converter quote was 15k.
What is the issue with current one?Rebuild might be more reliable than a used transmission.
problem with current transmission is that when i put it in D car does not move fwd
does it move if you put in L, 2, 3, D n R manually? Oil level, color and smell, share pictures here if possible. It better to remove the pan and check oil status, pictures would be helpful. Any recent work on the vehicle.
actually it was engine swap i put that engine+gear in RKR same position in all gears except in R and oil was in bad condition i have changed oil same thing found a small metal piece in pan
problem happened when i was driving at about at about 40 to 50 kph i have it some gas went to 80+ then slowed it down a bit i was on rough road after that no power jeep was not going more then 10 or 20 kph only engine sound no power to wheels
