I own a prius 2007 2nd generation. Yesterday I scan the car with my bluedriver scan tool and found DTC C1377. Although there is no triangle of death on dash or any yellow brake sign.after some research on google and prius chat I found that C1377 error code is related to auxiliary brake control power supply.
C1377 : capacitor malfunction.
This brake power supply is located beside 12v battery. When you opened your trunk. On right hand driver side you will see a black box along with 12v starter battery. So this code saying there is some problem with BCPS.
Guys I need to ask from you an expert prius electrician in lahore. Which can conform my observation and help me identify the oem replacement module. Thanks.
