My car had a accident and in result had replaced Front Right Side axle, tire rod, tire rod end and bll joint(chimta). Accident collapsedthe driver side.
All lights I had listed were illuminated an I got it examined which claimed that joint bush was brusted and grease was all over the rim.
After recovering from the issue, lights still prevailed and after I got it OBD scanned once again, following codes existed,
c1344 hydraulic system malfunction rear left
b1836 open in circuit shot airbag
c143
c144 brake control system failure/invalid
All these issues are regarding rear left side though I ner had any work done onto it.
Now after getting it examined hundreds of times in Lahore as well as Multan(my hometown), the issue is still present and I am sickout of it.
Need some technician to help me out.
Note; Non-Toyota Dealer told me that there are only two options now available, first is to do computerised brake bleeding( prius can't be bleeded manually as no pressure prevails) and if that won't solve the issue, unfortunately I would have to replace brake accumulator pump.
Sent from my iPad using Tapatalk
