AOA Gentlemen,
I have 2010 Prius 1.8 which has been going all smooth for last 6-8 months. Recently I have noticed slight changes in brake paddle. When in Parking or stop mode the brake paddle when pressed gives slight tick tick voices (like a relay switch) and also the ABS system gives voices and slight push back, feels like ABS is firing when paddle is pressed a little bit harder.
I've got the brake ABS sensors cleaned and brake pads cleaned (brake pads are original and are in good condition ) and problem is still there. Local mechanic says problem is with brake cylinder. However Brakes are working correctly at low and high speeds.
I need suggestions from experts how to deal with this situation, or maybe get contact an brake/ABS specialist in Lahore. Thanks.
