If you were using coolant then there should not have any rust on any of the pipes. I am afraid that suzuki coolant may not be of good quality and has caused corrosion in the system. Anyhow, remedy is to look for coolant leakage. Also do check the head gaskit for any leakages by performing the radiator bubbles check. In worst case, that might be the reason for coolant decrease.
