Vehicles with START & STOP Function -[ECO]
Stopping the engine
First put the shift lever in the neutral position when stationary, and release the clutch pedal. The engine will then stop. Next with the engine stopped, if the clutch pedal is pressed, the engine will start again.
The “ECO” indicator will light up in the instrument cluster when the engine has stopped.
A buzzer will sound as a warning when the following operations are done:
The shift is put into a gear position without the clutch pedal being pressed when the engine is stopped.
The driver’s door is opened when the engine has stopped temporarily.
Restarting the engine
Check that the shift lever is in “N” and depress the clutch pedal, the engine will re-start and the “ECO OFF” indicator will come on but when the vehicle starts moving, it will go off.
If you should want to disable the system, press “ECO OFF” switch.
To disable the system, press the "ECO OFF" switch. At this time, the indicator of the switch will come on.
