Hi guys,
I resolve the issue of eco system very cheaply, it cost me PKR 300/- only. I adopted the same procedure as discussed by mak313 in his earlier post but instead of replacement of that part (Shown in below picture) I cleaned that part with petrol and refit it and it start working normally.
Here is the procedure in detail with pictures:
Before removing that part place a clean pot under it because you have to pour that CVT oil again in CVT gear box.
Remove the stated part.
Remove that two screws only from it as shown in picture with help of flatted screw driver and small hammer, as good technician adopted the same procedure to open the tighten screw, after opening that screws asked the technician to make cut on the upper part of the screw with the help of iron cutting saw for easy refitting. If you found the 8 step star key then you donât need to adopt the above procedure to opening it (Normally most technician has 9 step star key which doesnât work on it).
As shown in the picture remove magnetic particles from the round shaped magnet with help of plug cleaning rotator or any other best procedure you can adopt.
After cleaning the magnet wash all the part of it with petrol thoroughly and make it dry before refitting it.
After refitting pour all the drained oil in the gear box again.
In the end before starting the engine remove earth (negative) wire from the battery terminal and replace it after a minute and start the engine, and after traveling one to two kilometer it will start working normally, if doesnât (Eco light start blinking again continuously) remove the cable again from the battery and replace again, Insha Allah your eco system will start working normally.
If your problem doesnât solve PM me I shall respond to you.
Thank you,
