kindly check and give an suggest hows this fitting is good to go with 1uz ?
Nicely done. I have made similar brackets for mine.You have a welder?
Welder mean guy who welds or Welding plant ?also brother what is yours Project ? is it 1uz ?
should i go With 1uz ? also which is better 1uz non vvti or vvti ?
Welding machine.It's a Honda inside a corolla.Depends upon your choice. I prefer keeping the same configuration of engine.Vvti is better.
Honda inside corolla interesting !Yes brother have one Its Mig & tig Welding Planti have 2 Option now one is an 2gr other is an 1uz brother can you do Wiring Work or any good Reliable Person who can do Wiring Work Hassan bhai
Great. Go for Mig first, then make yourself good enough to do Tig. Yes i can make a new harness. But car needs to be at my place. Both are good if you can mount them properly.
hassan your Located in Lahore ?
Yes sir. I'm from lahore.
so brother which is better 1uz or 2gr/3gr
also needs to Upgrade diff Because Stock Diff Maximum can Handle 150hp
Hassan bhai Do share Your Number aswel
Prefer the one you can get with the maximum parts. Whether it's Uz or GR either of them is going to make the car front heavy. So should be ready for it.Yes alot of thing needs to be upgraded.Pmed.
Nissan VQ is also an option.
