I decided to go a step further in the allmotor section and all out in every aspect. Parts have been rolling in since the last year and are still rolling in. The setup now would be as following:
Block
k24 88x99mm
Wiseco 14.2cr pistons (final compression 14.8-14.9 due to head chamber volume)
Manley turbo tuff i-beam rods
Acl bearings
Team4piston ported oil pump
Cometic head gaskit
Golden eagle oil squirter block off kit.
Arp Head studds
ATI k20 street damper
Inline pro timing chain tensioner
New OEM timing chain/guides/bolts etc
Head
Team4piston pro 163 CNC head
Ferrea valves
Ferreagold
roller rockers (vtec killer)
Supertech valvetrain
Team4piston K600 vtec killer cams
Drag cartel cam gears
Drag cartel VTC block off
Corsport vtec delete kit
K tuned hall effect TPS sensor
Induction
Kinsler 64mm Itb's (cnc'ed to match pro 163 head)
Exhaust
ASP megaphone header 3inch v-band (would be open header)
Fueling
VP Q16 fuel or Methanol
Prayoonto racing 1.9gallon fuel cell
Bosch 044 fuel pump
FIC 1650cc injectors
Weldon 2040 FPR
System 1 billet fuel filter
K tuned AN fuel fittings
K tuned -8AN braided fuel lines (feed)
K tuned -6an braided fuel lines (return)
Marshal 100psi FPR guage
Shifting
K tuned Race spec billet shifter
K tuned Race spec shifter cables
K tuned Shifter stops
K tuned Shifter cable grommet
Wiring/Electrical
Wireworx milspec engine harness
Wireworx race spec dash harness
Race-spec DIY fused relay box
Race-spec switch panel
Cooling
Koyo Half size radiator
K tuned rsx radiator hose kit
K tuned electric water pump kit
K tuned upper coolant housing kit
Blox high speed fan
Suspension
Yellow Speed custom drag coilovers (12k fronts and 16k back)
Blackworks racing Rear control arms
Blackworks racing Rear subframe brace
Energy suspension bushing kit
SPC front and rear camber kit
Trasmission
PPG 1-4th dog box gear
PPG final drive
Driveshaft shop 3.9 axles
Quaife LSD
CC twin disk
Rubber
MH 24.5/9.5/13 slicks
MH 24/3.6/15 skinnies
Weld Magnum import 13x10 black wheels
Weld Magnum import 15x3.5 one piece skinnies
Weight reduction
Cut doors
Cut hood
Cut trunk
Sound dedeaning removed
Seats/carpet etc removed
Dash removed
Ac blower/heater/firewall mat etc removed
No exhuast piping
No washer fluid bottle/No wipers/no ac compressor/no water pump etc etc
No useless wiring because drag car
No fuel tank
Safety
6point roll cage custom made by myself
Kirkey styled alluminum drag seats which would weld onto the roll cage (being made by a dear friend)
Racequip 5point harness
Might be missing a few stuff here and there,would be updating it as i get the stuff.
