That sounds brutally intimidating........ if that even makes sense
Mashallah farukh bhai, im out of words. I've seen setups like these but i never thought someone would actually do it in pak amd that too on a es. Hats off to your effort and hardwork bro may it all pay off
Sent from my E6653 using PW Forums mobile app
Hats off to you sir ! You should be in the news !
Sent from my SM-N910G using Tapatalk
Awesomeness at the END [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106]
I tip my hat to you sir. Impressive ride.
No words can define your effort behind this project !
What exactly happened after the run ?
How do u sit in this bare metal seat?
Sent from my SM-N920C using Tapatalk
Pictures look good. Dont get your point what happened after the run?
The brides have been installed today. Would posts the pictures in a while
Your one visit on track actually made fb pages mad today. I even read somewhere"first official drag car of karachi" lolBtw i have seen in videos hows the car running now and yourself playing on laptop sitting in the car And what happened to rocker cover where is that green one?
Sent from my H30-U10 using PW Forums mobile app
Yes I too saw videos on facebook while she running, rocker cover was silver, something went bad?Btw loved the short gearing.
I've videos too. Well I heard from the guys that alignment issue is there
Can you share the videos??
Heres the video. Car was on 9.5k rpm's and 24.5x9.5x13's MH slicks at 15psi. Still have alot of wheelspin issues!! Would now try running 8-10psi and see how it goes.
https://www.youtube.com/watch?v=YBi8mGnDZRw
there are some "surprisingly vague" comments on different fb pages and i had a good laugh seeing them. The green valve cover was taken off as i stripped one of the AN fittings while re-fitting the breather catch can's AN lines. It started to leak the oil from the loose fitting so i took it off.
Need to double check the alignment as its going sideways a little (btw the slicks tend to do this often as the sidewall is really soft,but not as much as it was doing on my car)
Yes i saw that as well it was way out even marks on road were way too uneven
Sent from my LG-F350K using Tapatalk
Here you go
Sir how much Hp it produce?? Any supposed Hp??
None of the pictures in this thread are loading for me ... anyone else facing similar issue on phone ?
Sent from my GT-N7100 using Tapatalk
