Ustaad Jee is working slow but he is definitely doing it good. The plan is;
1- To get the whole car finished from denting as much as it can be done.
2- Get the whole car sanded (even idea of sand blasting is under consideration)
3- Spraying of red oxide on complete car before any kind of body filling is done.
4- Re-sanding of the areas which look bad and then touching of red oxide on the sanded area.
5- Using of 3M or some other branded body filler to finish the joints of roof (specially on the C-pillars) and finishing.
6- Test fitting of all body parts like wind screens, front grill, lights, and door n trunk rubber lining to see if they fit ok.
7- Adjustments if required.
8- Final paint works
