hello to all....
some days before this was just an idea because of time management .this will work as indicator ON/OFF. finally did it hope you will like it..
things needed
1.LED strip easily available in market costed me Rs 40 p/yard
2.double tape original less wide
3.screw driver both plain and star
4.soldering gun
5.wire
6.cutter
1st of all remove mirror with help of plain screw driver
remove these screws
a lot of the dust would be here clean it with water and cloth
remove this rubber cap in the door near side mirror
put the wire through the motor connection line and get it out through this rubber cap (would be very difficult as i don't wanted to remove all the things so did it in this way)
and send it through fender to connect to indicator
here is the LED strip and double tape
clean the rubber from strip with help of cutter
solder a piece of wire to the points of LED strip with the help of soldering gun
stick it with double tape to inside of the mirror and connect the wire to previous one and here is the result
now put back the mirror to the fixative clips and enjoy
