vibration at any speed is bad, I would suggest you lift the car and check the driveshaft flex discs with a very strong 500W lamp, if you see cracks, replace the disc - also ensure the centre bearing carrier is intact and that the gland nut on the d shaft is tight, its not supposed to be super tight though.
If you want to do this repair I can write you the procedure and technique for it.
