JDMs ko "tuning" ki zaroorat nhi hoti .. sirf time pe regular maintenance karo ...
- engine oil/filter change every 4-6k KM depending on oil
- air filter and AC filter change according to condition / life
- transmission oil change at 40-50k interval
- brake oil check and top up if low
- radiator coolant .. check level and top up if low , full flush after 50-60k interval
brake shoe service (if needed )
spark plug check, orginals replace after 60-80k , if not original replace according to the plug condition and its manufacturers life
- throttle body service/cleaning after 20-30k interval or as required
aur working main koi bhi issue ho to car gives warning or error light on dashboard , you can then get it computer scanned aur issue ke mutabiq masla hal karwa lo
