I am using Wi Tribe 1mbps WiFi and I'm not satisfied with it. Most of the time it is on limited connectivity and is extremely slow. And it is a 8gb package which doesn't fulfill my needs.Now I'm thinking to switch over to PTCL wingle. How is its performance if we compare it to wi tribe. Does it provide stable speed ? I will be using 5 devices on WiFi through it? Please share ur experience
Sent from my A15 using PW Forums mobile app
Its good.but speed depends on distance ur location n tower/exchange.
Sent from my GT-I9300 using PW Forums mobile app
5 dvcs will perform quite easily
Go for evo wingle. Its speed is excellent. But again depending on your location. I mean, if you live in the city area, then its speed is good. But if you live in any outward area from the city i.e. any village, then may be its speed is slow. I advised you that first get any evo wingle from your friend and then check its speed in your area. If it seems good to you then go for it. Otherwise not.
Sent from my HTC Desire
Im located in Khe-Bukhari, D.H.A Phase 6, Karachi, do u think it will perform good here?
Im in in KHI and located in D.H.A near seaview, and sadly none of my friends have wingle , Im using Wi-Tribe and the speed and signals suck
you can use wingle. 1500 for the 20gb package... be advised that ptcl is very unreliable.. they will change their package limit without information. and also since the launch of 4g, their 3g has gone down the drain...
i have gotten nearly 600kb/s before... now its near to 200kb/s.. at exact same location. i have stopped recharging my wingle now...
i live in north karachi
Muradi bhai wingle lene se pehle meri wingle k upar detailed thread zarur parh lijega.
Now dropped the idea of Wingle , do u know any good internet provider?
Thanks alot bro, it was really helpful , now im not going for Wingle anymore, which is the best internet provider?
Currently, I am waiting for my PTCL package to end then I will switch to Nayatel as I have heard a lot good reviews about it here are their package information you can have a look at it Home Packages | Nayatel
Nayatel is very good, i have used it in Islamabad and it was awesome, but sadly its not available in Khi, if it was here i would have surely go for it
I saw the packages of nayatel wish it was available in karachi
True, there packages are attractive and quality is very good
Nayatel is really the best ISP.But you have to pay 27K just for their equipment to use Nayatel's fiber optic network!
What :-# ,i didn't know about that
To add to the misery you don't get those 27K back even If you return them the device back!27K policy is pure ****..
mera wi-tribe hi sahi hai
wingle is slow as evo 3g 500 per month, i take wingle from frnd try today no diff at all then come back to evo 500 per month
Whatttttt? 27K???
That's huge.
As per smart choice Nayatel looks impressive but as mentioned above 27K for setup is expensive man very expensive.
To compare PTCL EVO with witribe in terms of package rates and speed, you can use this site. Very helpful http://smartchoice.pk/internet/broadband/providers/ptcl/
