so I believe you are gravely mistaken, if you bought a pack of rings for a toyota 4AF, they are 81mm bore - whatever package you bought was wrongly marked, or of something else completely. Piston rings are imported in Pakistan in shrink wrap by the thousand count, the little boxes, wax paper and blister pack are made locally in Pakistan.
If you filed down the std size 4AF 81mm rings to sit in an 80mm bore on an 80mm OE piston - this is nothing new, its called jugaar ka ring and it never lasts as the rings never sit completely round in the cylinder, you actually damage the cylinder while this is running. There were lots of people trying this on almost all engines in Pakistan just to save money because for them "a revolving engine is a good engine" Ring gaps, ring/land clearance is not considered - infact most desi mechanics assume rings seal compression from their own tension and a polished like glass cylinder surface.
Rings for such engines are available but you have to purchase them from outside Pakistan as these engines were not sold in Pakistan in any car, same for gasket and rebuild set. I know they cost more because of duty and shipping charges but its a given cost when you buy a scrapped JDM engine.
Not belittling here, but consider what you just did for yourself -- This is a public forum whose posts are searchable by google, imagine the "kwaltee" of your service being showcased here where you are shoving larger rings into smaller bores.
If you dont believe that the google comment is true then look up toyota K410 CVT unit refill procedure, it probably is the most targeted page on PW - many people have landed on it from many different countries.
btw - that "hair thin" gap on rings is called ring gap and is a carefully measured clearance which is specced in the service manual, so is the land to ring clearance.
the ring gap on a QG18 are
C1 - 0.20 - 0.38mm l=0.49mm
C2 - 0.32 - 0.56mm l=0.65mm
Oil - 0.20 - 0.69mm l=1.09mm
the land/ring clearance is
C1 - 0.045-0.080mm l=0.2mm
C2 - 0.030-0.070mm l=0.2mm
Oil - 0.065-0.135mm l=0.2mm
You wont be getting these numbers with 4AF rings in a QG18
