LOL, for a Karachite even this is a beautiful sight!
Facing severe problems with the brakes on the Baleno. Rear brakes are locking under slightly hard braking making the car spin out.
it appears that proportioning valve is malfunctioning.
remove wash clean & bleed system again replace unit if rusted
When the picture is much more interesting than failed brakes,
Hyper miling guys actually do that. Crazy folks
Wild scenes.
Gave the interior a good cleaning. Whole process took around 3 days (stripping interior, cleaning everything and then putting everything back)
Got brakes serviced and bled. The problem has been fixed to about 80% but there's a slight whistling sound from the rear brakes, no idea why.The pads and drums seem to be in an acceptable condition and the noise comes after braking a few times.
if it is squeal as whistle the rear brake shoes shall be adjust 1 notch looseif it is hiss as in air release seems it is from boaster. not rear wheels.
@nnabeel
What if the booster make a meow kind a sound when u start the car and whoosh whoosh sound when u had to pedal hard or instant brake while driving ?
@nnabeel booster diaphragm is wet or leaky.
Took a one day round trip to Lahore last month. Speed was 140+ throughout and it took less than 3 hours to go from ISB to LHR
Wash day
Your AC needs service i reckon.
What makes you say that?
Oh well, that was easy. Your blower is on the maximum speed which clearly tells the story.
The blower doesn't work .For some reason it stopped working suddenly and I need to replace it now.
OooopsMy bad
Thats' a building with a Federal Govt offices inside. what your both cars doing there
