Bro u need to change at least transmission oil at 40k. Nd use toyota API GL 4 manual transmission oil. Also it is good idea to consult owners manual for periodic maintenance.
Other items to look for are brake nd clutch fluid replacement for lengevity of brake nd clutch cylinders nd over all the whole system. Bleed in correct order nd fill with new one, oem recommended.
throttle body service(this one is simple, disconnect batter, open air intake hose to throttle body, get a carb cleaner nd rag, remove all carbon build up from butterfly valve nd throttle body) since this dbw, so please remove negative battery terminal first, other u can end up with a chopped finger. Since it has no iacv due to dbw, so no need to remove throttle body from car.
Get all suspension parts inspected by jacking up the car nd looking for cracked or loose rubber parts.
Get cabin filter inspected, see if it is somewhat blocked. See if it needs cleaning or change.
Get AC evaporater inspected for dirt build, get it cleaned with water.
May be do a cooling system flush nd fill with new coolant.
Some of these are just preventive maintenancd steps.
I recently bought gli FL manual nd checking these things one by one nd finding that some items reallt need my attention although my ride does not give me any issues.
