[b]RaCE tuned kawasaki gto125[/b]
I was planning to buy a gto125 and race tune it this time wen i go to lahore, i am not really sure that i will be able to as i will have only 2 months in these holidays.
Engine
-Racing piston
-Oversized piston rings
-Big bore Aluminium cylinder w/larger cooling fins
-bigbore aluminium cylinder head w/larger cooling fins
-Racing crank, piston rod and bearings
-Port polish
-Titanium Valves and springs
-Engine chrome plating/anodising
-Aluminium/titanium bolts
Clutch
-Racing Clutch
-Aluminium flywheel
Gearing
-5 speed Customised gear ratios
Ignition
-Racing ignition coil
-Racing iridium spark plugs and wires
-Retard timing
Exhaust
-Custom build 2t titanium expansion chamber and silencer
Carburettor and Fueling
-Synthetic engine oil
-Custom fuel and oil filter
-2xcarburettors
-Carbonfibre reed valves
-Customized air box
-Racing air filter
Weight reduction
-Customised lightweight mudguards
-Custom lightweight front forks
-Short lightweight handlebars
-Custom longer adjustable aluminium swing arm
-Cutoff framework
-Custom shocks
-Custom sprockets and chain
-Lightweight racing seat
-Alloy wheels
-Front and rear disk brakes
-Aluminium /titanium bolts
-Removal of-Drum brakes
-Chain Guard
-Stand
-Stock meter
-Stock intigators
Appearance
-Custom Xenon Headlights
-Custom indiglow meter (rpm, speed, temp. fuel, battery, oil)
-Custom handlebar grips, levers
-Custom Brake lights and indicators
-flame thrower kit
-Custom Paintwork
-Neons
Other
-Racing tyres
Could this actually be done in lahore? If yes how much will it cost?
