but when i floor the gas, the coolant flows out...sometimes it does, sometimes it dont. confused!
can someone suggest me supreme coolant and step to step instructions to add up coolant.
thx
How is the mobil oil condition? If head gas kit is leaking water may be mixing with oil and making a curd, just check that. I also went through this with my previous Khyber.
Engine oil is fine and no mixing with radiator water. One of the symptoms of a faulty head gasket is the mixing oil with water in the radiator. I m thoroughly concerned abt the decreasing of water in the reservoir. Some one here suggested pressurising the cooling system to check for leaks. Isn't it a little risky as it can possibly lead to damaging the pipes and certain seals, especially the water body/pump area?I'd appreciate if some1 here can post a schematic depicting the basic working of the water body.
Yes, that'd be the proper way to do it. Mine was just a desi mechanic.Point is, to check the rubber hoses. One of my friends had a leak in a small rubber pipe that takes water to the throttle body. Good thing is that since he had coolant so the mechanic (he went to the honda 3S) was able to see green residue and detect the leak...again a tiny hole.
Off topic but couldn't help noticing, although I myself am a total auto-repair-noob, but the seal between the cylinder and engine block is a head "gasket"
In Pakistan Ive come to know that most people just tend to follow what people say and dont actually look up the correct term
hence gasket becomes gas kit, or jane, or some other completely stupid word.
anyone
Reducing water on daily basisPossible Causes1- Leakage of radiator,house pipe or faulty cap valve.2- Evaporation due to water body malfunction
How can water pump/body malfunction to cause water evaporation?IMO, the purpose of water body is to circulate the water through the entire cooling system. The only malfunction that can occur is that it'll stop working or it can leak. No malfunction can cause water in the cooling system to evaporate. Experts, correct me if i m wrong here.
radiator drinking up the water as a camel ... hahahahaha check your car to some mechanic on pit u will find falt nice heading i am still laughing
