try following..
check all the hoses for cracks..once coolant is pressurized it seeps out of these cracks and immediately evaporates being hot...
radiator cap may be rusty and its not sucking the water back from the reservoir ..
go to some good mechanic and get your cars radiator flushed.. probably the rust has accumulated in its tubes and circulation of water is not proper..
check speed of radiator fan.. get it increased
faulty thermostat valve can also lead to these problems..
finally its the gas kit.. if its not the gas kit then its the radiator itself.. if situation arises that radiator requires to be changed .. then get it replaced with the one having double tubes..
