Hi,
I am facing a very complex issue in Suzuki Liana.
When the RPM is under 2000-2500 the car runs very smoothly and there is no problem while driving.
But when I drive the car on Motorway, And the RPM goes above 3000, the radiator start overflowing water from radiator to the reservoir and ends up heating once the entire water is finished from the radiator.
I have changed the radiator cap
I have cleaned the radiator as well.
Replaced the radiator as well.
But still I am facing the same issue.
Now, some mechanic in RWP has suggested to change the head-gasket which is creating pressure and letting the water overflow from the radiator.
What do you guys suggest?
