World's First RTF jet capable of deactivating/activating the vector system by just flipping the vector switch on the transmitter. This feature is perfect for both beginner and advanced pilots. This NEW Super F-16 is the BEST 360 degree full axis vector thrust VT jet in the market! It features a new dimension in RC jet flying! With the newest 360 vector thrust technology, pilots are able to perform almost any maneuvers in the air!
Features: -
> NEW Version 2 - Improved retract doors
> NEW Version 2 - New vector thrust system (plastic ball socket design)
> 7 Channel Full Function Radio Controlled (Aileron,Elevator,Rudder,Throttle,Retracts,Vector)
> 2.4GHz spectrum technology, with the functions of automatic identification and precise code pairing, strong anti-jamming, and allow more than 20 aircrafts to fly at the same field at same time
> Full Functional 360 Degree Nozzle with Thrust Vectoring
> Full Functional Aileron Control
> Full Functional Tail Rudder Control
> Full Functional Elevator Control
> Full Functional Mechanical Retracts
> Steerable Nose Gear
> High Performance Turbo 70mm EDF matched with ultimate Brushless Motor and Brushless ESC
> Excellent Scale and Detail
> Excellent Maneuverbility
> One of the best ducted fan jet in the market!
> Perfect appearance and emulation (Scale appearance, great attention has been given to details)
> Can Take Off From Ground or Hand Launched (Experts Only)
> Fuselage with pre-installed Electronics, Motor, Servos, and Speed Controller
> Superb Quality, Simply the Best RTF Jet you can find!!!
> One of the Best Looking Jet in the market
> Excellent stability and aerobatic capability
> Detailed Body Structure
> Approximately 15 minutes flight time on each charge - Optional Li- poly battery will help to achieve better performance and longer flight time
> Complete Kit, Ready to Fly
Specifications: -
> Wingspan: 815mm (32 in)
> Length: 1300mm (51.2 in)
> Drive System: 2400KV Outrunner Brushless motor
> EDF Diameter: 70mm
> Servo: 12X 9g high speed micro servos
> ESC: 50A Brushless speed controller w/ 5A BEC
> Battery: 18.5V 5S 2200mAh 25C Li-Polymer
FINAL PRICE: Rs. 65000/-
NaiTazi Ads Add Link: The link has been removed
