Originally published at: https://www.pakwheels.com/blog/read-tips-maintain-tire-efficiently/
As automobile lovers, we all tend to care for our car and maintain it as well as we can. We maintain the engine, the interior and exterior of the car very well. However, we often forget to take care of the tires, which are mostly facing the beat as it is the only component of the car which is in contact with the road.
First off, always remember to get the rotation of the tire done after every 10000 kilometers, it will help the tire to work efficiently in the long run. Moreover, keep this in mind that wheel balancing of the tire is essential, and if you neglect this aspect, it will inevitably cause damage to the tire. Wheel balancing will not only give you vibration free ride but also prolong the life of the tire.
The other tip is that always look for the air pressure of the tires because if the air pressure is too low or high, it will undoubtedly cause perilous damage to the tires—in simple terms the tire might blow out, risking the security and safety of the passengers.
Furthermore, to maintain and increase the lifeline of the tire use protection products and apply them on tires twice a week.
Moving onward, always keep a close eye on the tread of the tire. You don’t need any external help to do your bidding, just get down to the tires and thoroughly inspect them. And if the tread of the tire is less than 3mm replace it at once without wasting any time if you want to live longer.
These are some simple tips which we have devised for our readers; you don’t have to go to car maintenance center to do the things mentioned above, you can easily do these in the comfort of your house. And the important thing is that it is less time-consuming.
