almost everythign on my engine except crank and case are new so it has alot of potential, only problem i keep running into is the lack of fuel since i'm using a tiny 31 carb on my 1600 when i'm supposed to be using at least a 34 (bare minimum) or ideally a single 41 or dual 34 setup.
for the tests i'll have to overfuel the engine till the runs are done to compensate for the "upgraded" air:fuel ratio.
worst case, if it breaks i'll just rebuild it as long as i don't crack the case (not likely since i'm limiting the revs to 5000rpm.
i'm not going for top speed, but rather more of a kick so that in 3rd and 4th (while driving) i can get an instant boost of power so i can get the run on the rolla and civic babies.
i know i'm asking for trouble so it'll be a few short runs with limited NO2 as i don't have a roll cage or discs (yet), but since i'm only targeting a 10-15hp improvement with the mix i'm planning i should be ok.
