just from the drive home i found that i must address the following issues:
Alignment (front wheel is off by about 20 degrees)
replace gearshift rod (current one is broken)
new engine rubber (currently has beetle one but needs bus one)
Pedal rubbers (currently metal only)
Brake adjustment (not checked yet)
Exhaust system (current setup is venting under car rather that through the bumper)
Headlight (only have one)
Tail lights (don't have any)
Front indicators (don't have any)
Drivers seat swap/repair (broken hinge)
Sun visors (driver side is loose)
Door removal clips/stays (need new ones)
Floor boards (this car will NOT have carpeting)
Tyres (will be swapping the tyres off from the 1303)
Glovebox lid (left it at the mechanics)
Steering wheel (have to remove the tiny wooden one and replace it with a VW unit)
Steering column (has a corolla one, need a VW unit)
New roof (current soft top has shrunk!!!)
Replace beading under windscreen (worn out)
roof frame clips (front locks are worn out)
there is ALOT more stuff which will need to be done before i take her out of the house again, but don't expect miracles till i make another trip to europe as most parts for this car are not available in PK.
