well may be he has actually trimmed down the fuel ,,,,,,,, as I never drive 2L engine before so I cant compare it with anything but just recently one of my friend drive it and he said its lacks power ,,,,,,,,,,, but I am really not willing to do anything with this engine, I will try to swap back its original engine/gear ,,,,,,,,,,,,, and that roaring noise is I think because of oil sunk air filter and no sound box ,,,,,,,,, I have changed the entire air filter box and that noise has almost gone but it still need a sound box ,,,,,,, radiator I have already changed and its working very well ,,,,,,,,,,, no overheating issue till now ,,,,,, engine is less noisy after these 2 mods ,,,,,,,
measuring input drag torque ,,,,,,,,,,,,, I don?t have any tool and skill to do It at this time ,,,,,,really I am not happy with this steering system ,,,,,,, first it was leaking and I fixed it after changing all the seals of steering box and also completely flushing the system including reservoir bottle plastic filter ,,,,,, but its still hard ,,,,,, and also now it got atleast 2.5 inch steering side play ,,,,,, manual say it must not exceed 1.38 inch ,,,,,,,,, steering become too hard on idle engine and also on normal use but as soon as I push the pedal to the limit it become smooth ,,,,,,,,,, under all normal use it stays rock hard ,,,,,,, I think its because of the weak hydraulic pump ,,,,,,, at this time I don?t have any pressure gauge to verify it but I am sure it?s a faulty hydraulic pump ,,,,,,,,,,, new pump is not available in market ,,,,,,,,,,, second hand kabli pump is available in around 10k ,,,,,,,,,, as I just need a cheap temporary fix so I plan to rebuild it ,,,,,,,,, its a vane type pump and I think It can be rebuild ,,,,,,,,,, previously I rebuild the break vacuum pump of this car which is also a kind of rotary piston with vane on it ,,,,,,, break become rock solid on idle and now its working find after changing all the vanes ,,,,,,, new vanes of exact size were not available so I buy a bigger one and hand fabricate all of them ,,,,,, but yes that vacuum pump was lot simple then this hydraulic pump but I will gave it a try ,,,,,,,, its a kind of working blindly without having the right tool for the right job ,,,,,,,,,
