do not install generic off the shelf rims on your daewoo racer, your car has hubcentric wheels meaning that the actual load of the car is on the hub snout of the wheel and the wheels themselves are sitting flat on the hub face, the bolts are there just to keep them in place. There were 2 types of bolts used, conical seat bolts and ball seat bolts - and you need either new bolts or matching wheels to your original lug bolts.
If you use non-hubcentric wheels - they will come off the car when in motion. And double check the offset of the wheels you install, they should completely match the original otherwise you will have very stupid steering behaviour.
For any alloy wheel for your car, the mount face should be flush and the hub centre bore should be a tight fit on the hub snout. In countries out of Pakistan you can buy centre sleeves for such purposes. In Pakistan the wheel shops are super arrogant in dealing. I wonder how they do business.
