I have this
https://www.bosshome.com/product/air-cooler-ecm-7000/
consumes 145 watts including the water pump and fan motor (didn't check swing motor power consumption as I don't use that function)
with 35C intake temp with approx 20% relative humidity, delta T is approx 10-11C (got these figures 2 days back, in Lhr)
only thing I miss is, ball float valve, other than that it's okay
I hope that helps
@roboxx
further info if you're interested
on average, nowadays it's consuming approx 6.66 Litre water per hour (I fill 10 litre every 1.5 hours)
and my room volume is 60m³
in lhr, today max temp was 44
inside home, cooler air intake temp is +-35-36C
and temp in room is 30.4-30.5C with 40-45% relative humidity
I have dc ceiling fans too so I turn on both fans simultaneously at no 2 alongside with cooler, each fan consumes 15 watts at no 2, add those 30 watts too
cooler 145-watt and 30-watt fans
so with 175 watts, I'm maintaining +-30.5C in a 60m³ room which is relatively cheaper as compared to ac
last night, ac was consuming 1.18 amps (260 watts) for maintaining 29.5C in the same room
