Hi there,
I have Suzuki GD110S. recently past six months I am facing very frequent puncture in rear tire. It is 2.75 R17 Diamond. I have replaced four tubes in past six months. Since tube of my tire size 2.75 R17 is not generally available so I have no choice except to use tube for China 70 bikes tube size (2.50 R17) or honda 125 tube (3.00 R17). Both have failed and at least one puncture per week I have to face. My exact size tube 2.75 R17 is not available easily.
now there is a vast range of brands for tire for my bike size 2.75 R17. If I replace with original recommended size there is no hassle other than same issue that after tire replacement there will come a time to change its tube when it will get four or more punctures. But again back to same problem. the tube of this tire size 2.75 R17 wouldn't be easily available in local market.
Please recommend proper tire size and make so I can replace my front and rear tires
second issue with my rear wheel is alloy rim was striken suddenly in a deep pit. it got little band from one side. how can this be corrected. At the moment bike running is not smooth due to bent rim.
third problem is that I have changed the ball bearing cone set of steering handle. its gap is adjusted fine and there is no play in steering. But when I go to un even road at I get minor strikes on handle as if handle cones are loose. but they are not
