Well theres one issue here
The manufacturer only cares about getting it out of warranty period, the max is 100000 kms globally.
E.g. toyota rtv i mention fails with their own specified coolant but fails very slowly and usually by 90000 kms and if left unchecked causes headgasket failures.
Similarly they engineered engines with actual design faults which show up after 90000 kms. But anyway, from experience I can tell you that there is no transmission in the world that doesnāt require fluid maintenance but toyota say otherwise (to get it out of warranty)
But I also know that if you dont schedule maintenance for your equipment, your equipment will schedule itself at the worst time.
