Title says it all.
Ive got a 3 year old swift ( bought it when it was first interdouced by pak suzuki for 11 lak )
its a DX manual 1.3
after the warrenty period expired ive been using attock 20w-50 oil in it, the one in the red bottle; but is there any better alternative in the same price ( would not like to pay more then 1.8-2k for oil )
Also uptil now ive been using water as coolant, should i change over to manufactured coolant (and if so which one ) or more water?
and oil and air filters need a change, should i go for suzuki OEM or can i find something else thats better in the same price range.
finally, the window washer system seems to be jammed. when i pull the lever from inside i hear the motor pump wizzing, but no water comes out; even with a full tank ( and it seems that the window washer tank fills up too quickly )
