Bro how did you get these petrol figures in khi? Mine doesnt go over 9km/l with ac inside khi...its cng fitted though and must be suffering from air blockage/timing etc
Is it okay to use 5-50w engine oil?
Zic 10w-40 is best for cultus
best for carby cultus 2000-2007not for efi cultus 2007-2017
Zic 10w-40 is best for Non EFI Cultus in Winters and Zic 20w-50 is best in summers.
I'm using shell hx5 10w40. Works perfectly fine and I change the oil at 5000 km.
how many litres of oil is required for efi cultus?
3.5 liters
what is a difference between KIXX G and G1,?Currently using KIXX G and results are perfect,
AoA, I am driving Cultus 2015 old shape. I need suggession, current mileage is 180,000km. Which viscosity is good for it...??? my mechanic start giving me PSO 20w 50 for last 6 months. I need to know is it ok, or I need to change...???please reply
if the engine is fit, there is nothing better than 10w30 caltex. However no guarantees on a worn out engine, it may start to burn
Go for Caltex 10w40 api SL. Monitor the oil level for 3,000 kms and if it decreases the level, then shift to shell 20w50 api SL. Do not go beyond API SL since your car has flat tappets and it requires an oil that is abundant in zddp. API SM and above lack the required amount of zddp for flat tappet engines
I have purchased Cultus 2011 model 115K driven which oil is best for it as previous owner has not confirmed its history but he said might b United 20/50 was used now its confusion so plz need some expert opinions
