AOA,
Here is the additional of one more Award winning SQ unit in my collection.... i hope you like it
[B]Quick Overview[/B]
Soundstream 4 channel REF800.4 REFERENCE REF 800.4 With the new Reference Series is SOUNDSTREAM before a superior amplifier series. In the precious heat sinks, there are visionary innovations, best components and high-class technologies that can advance the series to the reference of the future. Rarely has a amplifier series so much attributes of high-end philosophy has united in itself - whether for audiophile-quality sound systems or high performance systems that are REFERENCE series first choice. In the high-end special issue of the journal autohifi the REF800.2 debuted with incredible 2 x 456 / 692 Watts RMS at 2 ohms or 1, and was rewarded with [B]25 points and 30 sound the best rating[/B]`re top class! The 4-channel model REF800.4 REFERENCE sister won the debate in a comparative test with a fantastic idea 07/2006 winning first place in the top class! Both models were of the editors with the highest rating in the sales value - 6 Stars -
Excellent FEATURES:
high pass filter 30 - 4000 Hz />
Subsonic filter 10 - 100 Hz
Hawkins Bass Control 0 - 18 dB
Hawkins Bass EQ 18-80 Hz
input sensitivity from 0.15 to 12.0 V
Bi-linear crossover selector
mega-FET power supplies
Gold-plated RCA connectors Balanced line inputs
2 Maxi Gauge Power Terminals
Special coated heat sinks with optimized heat dissipation RUBI ā¢ - pulse-controlled power supply
STACT ā¢ - Reduces harmful voltage spikes by 50% Trident ā¢
- 3-overload circuit
Harmonic Bass Alignment ā¢ - Precision Bass-circuit
IDI ā¢ - Protection status display
BIP ā¢ (Bias Input Protection) & ndash ; bias protection circuit
Ultra-Low ESR Capacitance Bank - Hi-Speed Power Supply Technology 4 x 125 / 200 watts RMS at 4 / 2 Ohm HP LP filter 30-4000 Hz,
Hawkins Bass - Control 0-18 dB,
Hawkins Bass EQ 18-80 Hz,
Subsonic Filter 10-100 Hz,
0.15 to 12 V input level
Triple Darlington output circuitry
THD <0.02%
SnR 115db
Damping Factor >500
<table class="list-item-list-info" cellpadding="0" cellspacing="0"><tbody><tr><td style="padding-right: 5px;">
</td><td id="product_id">
</td></tr><tr><td style="padding-right: 5px;">
</td><td>
</td><td nowrap="true">
</td></tr></tbody></table>
