As new parts arrived reassembling process was initiated by soaking Drive plates in lube.
After an hour of soaking, Drive plates / Driven plates were installed alternately one at a time.
Clutch cover plate and springs installed.
Tightened springs in opposing sequence by making sure that pressure on plates be kept equal at all sides.
Gasket bond applied to Clutch cover, gasket placed and clutch cover bolted to engine once again in such a way to keep pressure as equal as possible at all sides.
Wait for half an hour, pour in lube, wind-up clutch adjustments, crank starter and here you go with a reinvigorated bike at your command. (H)
