I have installed a relay in my suzuki mehran. This is a relay box with 3 relays + 1 fuse. I have read in some forums that excessive current can burn the silver inside the lights. I am using 90/100 tubes in my lights. I have turned lights on for only 5 minutes and then touched the headlights and they were very very hot. I wonder what will happen on 3 hour drive? Pls advise as I don't want to be in a mess when out with my family.
2 of these relays are for headlights (high/low) and 1 relay is connected to CNG kit. Short ciricuit is not a concern here as there is fuse in the relay box too.
Pls also comment on the relay for CNG is it a long term solution because I was having problems in starting on CNG therefore one electrician attached a relay, it worked for a few weeks and then another missing problem on cng started. Then electrician changed another coil and it worked sound for 6 months and I am having the same problem again.
CNG Problem: Car starts fine on CNG and drives fine until 15-20minutes plus. After this when I SLOW it on a jump/breaker it shuts down (as the accelerator completes stops giving race despite pushing the pedal to stop it from shutting down). After this it won't start on cng but only on petrol and then it may be converted back to cng on the drive. I have also noted that when the car shuts down and if I leave it shut down for 5 minutes at-least and then try starting then MOSTLY it starts on cng.
Is it something related to relay/wiring problem which might be over heating the CNG kit? Or my cng kit needs servicing for cleaning of any dust/junk in the cng?
CNG kit is installed is 7 years old and the car is 99model means wiring is also old but off-coarse its been repaired routinely. I will appreciate if I will receive some tangible/technical replies instead of generic replies like: get your wiring done/cng kit services etc etc.
