Hi PW members;
I wish to know that does replacement of Diahatsu Cuore old point ignition system with Kabli CDI system improves the over all current supply to Car and helps to burn fuel better resulting a better gasoline milage...???
Furthermore, should I install thermostat valve and keep engine cooling fan setting on automatic in my recently rebuilt engine or let it be direct as recommended by most of the machinics in Karachi.
Would be great full if expert from this worthy forum Please share pros and cons of keeping the cooling fan setting on direct from battery.
